I have an issue using the scheduler for this script. Is this something that MT should fix? Or perhaps this is an access/permission issue?
This script works when running it manually or via the terminal. However, the scheduler can’t run the script.
CLI
/system scheduler
add interval=8h name=container-nginx-backup on-event="/system script run container-nginx-backup" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-time=startup
add dont-require-permissions=no name=container-nginx-backup owner=user policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":log info \"Nginx-Backup started\"\r\
\n\r\
\n:log info \"DATABASE\"\r\
\n\r\
\n/tool fetch address=\"ip\" src-path=\"/pcie1-part1/containers/mounts/nginx-proxy/data/database.sqlite\" user=\"user\" mode=\"ftp\" password=\"pw\" dst-path=\"mounts/nginx-proxy/data/database.sqlite\" upload\
=yes;\r\
\n\r\
\n\r\
\n:log info \"Nginx-Backup finished\""
