Can any help with command ?
/ip route print where x.x.x.x in dst-address and bgp
/ip route print where 90.189.192.0/19 in dst-address and bgp
do nothing i need some look like this
BGP routing table entry for 90.188.192.0/19, version 237336458
Paths: (2 available, best #1, table default)
Multipath: eBGP
Advertised to update-groups:
3 5 6 8 9 12 15
18 19 22
12389 41440, (received & used)
195.34.52.208 (metric 24) from 195.34.52.181 (195.34.52.181)
Origin IGP, metric 0, localpref 120, valid, internal, best
Community: 8359:200 8359:5017
Originator: 195.34.52.208, Cluster list: 83.59.83.59
195.34.52.208 (metric 24) from 195.34.52.182 (195.34.52.182)
/ip route print where 90.189.192.1 in dst-address and bgp
Leave off the netmask, and choose an IP in that network. You will get all routes (not just the most specific one) that match that IP.
I am well aware of the IOS command you are trying to emulate. You’re not going to get IOS output on RouterOS, however, since it isn’t IOS. I do not have any ROS BGP routers (only IOS ones), but the below works for OSPF so you may find something similar in the BGP section. It won’t summarize everything nicely like IOS does, though.
/routing ospf route print where 10.255.255.233 in dst-address
So how i can see bgp routing table, community , path and etc ?
/ip route print detail where 90.189.192.1 in dst-address and bgp
/ip route print detail where 8.8.8.8 in dst-address and bgp
action timed out - try again, if error continues contact MikroTik support and se
nd a supout file (13)
Fullview about 335000 records
