HI All,
We are trying to utilise the L2TP service from Andrews and Arnold to present a fixed IP on a Chateau 5G router to allow us to build a VPN tunnel between our main site Firewall and a temporary site on 5G. We have configured the AA service and are receiving from it but not able to transmit to the service. We would like our external IP to present as the IPv4 from the L2TP service. We believe we are having issues with the NAT and have reverted the configuration only leaving in place the L2TP config. Can you please provide any guidance on what we would need from a NAT and FW perspective to allow this connectivity.
We also noticed that we could use dial out VPN, would this be an applicable solution to deliver the same goal?
jun/13/2023 15:17:42 by RouterOS 7.8
software id = TMEG-8V56
model = D53G-5HacD2HnD
serial number = xxxxxxxxxx
add admin-mac=18:FD:74:AB:FB:20 auto-mac=no comment=defconf name=bridge
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" nr-band=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country="united kingdom" disabled=no distance=indoors frequency=auto
installation=indoor mode=ap-bridge ssid=xxx-xxxxx wireless-protocol=
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors
frequency=auto installation=indoor mode=ap-bridge ssid=xxx-xxxxx
wireless-protocol=802.11
/interface l2tp-client
add add-default-route=yes connect-to=xxx.x.x.xx default-route-distance=3
disabled=no max-mtu=1500 name=AA-L2TP user=xxxxxxx
/interface wireguard
add listen-port=13231 mtu=1420 name=remote_admin
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=wap.vodafone.co.uk ipv6-interface=lte1
use-network-apn=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile
/interface wireless
add disabled=no mac-address=1A:FD:74:AB:FB:26 master-interface=wlan2 name=
wlan3 security-profile=profile ssid=FA-Guest
add disabled=no mac-address=1A:FD:74:AB:FB:25 master-interface=wlan1 name=
wlan4 security-profile=profile ssid=FA-Guest
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/interface bridge filter
add action=drop chain=forward in-interface=wlan3
add action=drop chain=forward out-interface=wlan3
add action=drop chain=forward in-interface=wlan4
add action=drop chain=forward out-interface=wlan4
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=wlan4
add comment=defconf interface=lte1 list=WAN
add comment=defconf interface=AA-L2TP list=WAN
/interface wireless access-list
add ap-tx-limit=16 interface=wlan4
add ap-tx-limit=16 interface=wlan3
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid log=yes
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
connection-state=established,related disabled=yes hw-offload=yes
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment="defconf: masquerade"
add disabled=no distance=1 dst-address="" gateway=xx.xxx.xx.xxx
routing-table=*400 suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system logging
add topics=firewall
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
source="\r
\n :if ([system leds settings get all-leds-off] = "never") do={\r
\n /system leds settings set all-leds-off=immediate \r
\n } else={\r
\n /system leds settings set all-leds-off=never \r
\n }\r
\n "
/tool mac-server
/tool mac-server mac-winbox
