Android always-on IPSec problems
Hello
I’m trying to set up some android devices with always-on IPSec VPNs, using IPSec with x-auth/psk. I can connect fine with the devices normally, but when i turn them to ‘always on’, I get this error in the logs:
oct/08 20:12:17 ipsec,debug ipsec =>: rejected authmethod: DB(prop#1:trns#1):Peer(prop#1:trns#1) = XAuth pskey server:GSS-API on Kerberos 5
oct/08 20:12:17 ipsec,debug ipsec =>: no suitable proposal found.
oct/08 20:12:17 ipsec,error failed to get valid proposal.
oct/08 20:12:17 ipsec,error ipsec =>: failed to get valid proposal.
oct/08 20:12:17 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
oct/08 20:12:17 ipsec,error ipsec =>: failed to pre-process ph1 packet (side: 1, status 1).
oct/08 20:12:17 ipsec,error phase1 negotiation failed.
oct/08 20:12:17 ipsec,error ipsec =>: phase1 negotiation failed.
Here’s the peer config:
add auth-method=pre-shared-key-xauth enc-algorithm=aes-256 generate-policy=port-strict hash-algorithm=sha1 mode-config=xauth_mobile nat-traversal=no passive=yes policy-group=xauth_mobile
And the proposal:
add enc-algorithms=aes-256-cbc lifetime=8h name=xauth_mobile pfs-group=none
Also tried using certificates and hybrid RSA/PSK, same result. Is there any hope of getting this working? Anyone done it successfully?
Anyone? Mikrotik?
Last bump before I give up. Anyone have any ideas?
Look at the first line from logs. It means that client is no longer using xauth authentication.
Google thinks it’s the router screwing things up. I am sure it isn’t, but I guess it’s just not possible. Any idea if RouterOS will support any of the GSS-API stuff?
If it is Mutual RSA+Xauth then we have plans to implement it in the future versions.
