Android devices Dont get a splash page
First time seeking assistance, thank you in advance for any advice you may have.
My company implemented a dual Mikrotik system using vrrp and some syncing scripts. I researched vrrp setups and it seems pretty straight forward and looks correct, to me anyway. However some devices can not get a splash page when connecting to our wireless network, specifically Androids struggle the most and some laptops here and there. These devices are unable to ping outside the network or to the gateway (X.X.X.1). The twist, if a device pings either of the routers in the VR group (X.X.X.2 or X.X.X.3) suddenly all ping requests are successfull, the splash page will appear and traffic flows as it should. Removing the vrrp configuration will also fix the issue but then I have no redundancy.
