Android Mobile App Feature Request
There does not appear to be a dedicated forum for the mobile app, so I did not know where else to post this.
Can you please add the option to sort the list of Saved devices by their Note
I have over a hundred devices in this list and without sorting its very difficult to find a particular host. I realize the search magnifying glass button is there, but I would prefer an ordered list to begin with.
Thank You
Could you please introduce the possibility do delete all saved connections?
I have hundreds of them, and need to reload them from time to time from my other machine. In order not to duplicate, I have to be able to delete existing list.
At this moment, the only workaround I am aware of for cleaning the existing set of settings is to uninstall and reinstall the app.
There is only one official thread on that and it can be found here:
http://forum.mikrotik.com/t/mikrotik-smartphone-app-ex-tik-app/89458/1
