I have 2 CAPs I provision. On the 2.4 GHz bands, the channels selected often overlap, or are sometime the same! I thought CAPsMan checked the nearby channels before selecting the least occupied one. Is this not true? How can I avoid this? Config is posted below.
Thanks again to all.
Regards,
Dave
aug/19/2020 18:07:47 by RouterOS 6.47.1
software id = M86E-F0VR
model = RB4011iGS+
serial number = 968A09471487
/caps-man configuration
add channel.band=2ghz-onlyn channel.control-channel-width=20mhz
channel.extension-channel=disabled country=“united states3”
datapath.bridge=bridge datapath.client-to-client-forwarding=yes
datapath.local-forwarding=yes max-sta-count=30 name=“2.4 WAP”
security.authentication-types=wpa2-psk security.encryption=aes-ccm
security.group-key-update=1h security.passphrase=XXXXXXX ssid=WAP
add channel.band=5ghz-onlyac channel.control-channel-width=20mhz
channel.extension-channel=disabled channel.save-selected=no country=
“united states3” datapath.bridge=bridge
datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes
max-sta-count=30 name=“5 WAP” security.authentication-types=wpa2-psk
security.encryption=aes-ccm security.group-key-update=1h
add datapath.bridge=bridge datapath.local-forwarding=yes datapath.vlan-id=10
datapath.vlan-mode=use-tag max-sta-count=5 name=“2.4 Guest”
security.passphrase=“YYYYYYYY” ssid=Guest
add datapath.bridge=bridge datapath.vlan-id=10 datapath.vlan-mode=use-tag
max-sta-count=5 name=“5 Guest” security.authentication-types=wpa2-psk
security.encryption=aes-ccm security.passphrase=“YYYYYY” ssid=
Guest
/caps-man access-list
add action=reject allow-signal-out-of-range=2s disabled=no signal-range=
-120..-71 ssid-regexp=“”
add action=accept allow-signal-out-of-range=2s disabled=no signal-range=
-70..120 ssid-regexp=“”
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=
“2.4 WAP” name-format=prefix-identity name-prefix="2.4 "
slave-configurations=“2.4 Guest”
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=
“5 WAP” name-format=prefix-identity name-prefix=5 slave-configurations=
“5 Guest”
