Recently I bought a pre-programmed mikrotik router. I Do know some networking stuff but it would take to much time to learn the mikrotik and I needed to make it work quick.
So now I am able to login to the vpn. when I check my public IP address it is changed to the microtik’s public IP. And when browsing even the DNS filter/redirecting is working, so that’s cool!
From my laptop on a terminal window I can ping to the remote-local-lan-mikrotik-address.
From winbox I can ping back to my laptop.
but I cannot access web interfaces of other device on the remote lan.
I’ve set proxy-arp on the LAN bridge interface.
now how do I post the parts of the config here so you guys can help me out?
Can you give an example of what you are trying to access when you say web interfaces? If you are on an L2TP tunnel you should be able to access other LAN devices…
Thanks for your reply, the default gateway is the same for all devices. and is the internal ip of the microtik.
when I am connected with the VPN I can ping the internal IP of the mikrotik, but cannot access the web interface. I cannot reach any other IP on the network.
I can access the mikrotik web interface only through one of the public IP address. (I have configured dual wan.)
I am trying to access the web interface of different access points in the remote LAN through a vpn.
Yes all devices on the network use the same gateway. gateway is de microtik LAN IP. When I am connected through the VPN I can ping the gateway and get a normal response but I cannot access the web interface with it’s IP address.
I can access the mikrotik web interface on it’s PUBLIC IP.
I cannot ping any other devices in the remote network.
I would start by checking NAT and access rules. As you have access to the web interface on the outside IP while you are connected with VPN, this should be simple enough.
