Another overlap subnet remapping (CarPlay)
Hey. I have a wireguard road warrior configuration (WG is running on a VM outside Mikrotik) on a couple of mobile devices. When connected my vehicle’s CarPlay, the carplay network overlaps all of my subnets, including all my site-to-site routes. The carplay is 10.0.0.0**/16**, I have subnets 10.0.2.0/24, 10.0.3.0/24, 10.0.4.0/24, 10.0.5.0/24, 10.0.6.0/24, 10.0.7.0/24 scattered across various sites. I don’t know why they picked a /16, it makes no sense for a point-to-point link.
I’ve solved this by using nat and connection tracking to remap the subnet, then updating the apps to use this remapped address.
This works both on a wg connection, and when my phone is back on my home wifi.
I have only done this for a 3 hosts locally on the router’s lan as proof of concept, and it works fine.
The problem is, Is there a way to map an entire /24 to another /24? Having to make a srcnat+dstnat entry for every host on every network seems like the wrong thing to do. This could end up being 1500+ nat rules. I then have to duplicate these rules onto the other sites for the same behavior
Or is there a better way in general to do this?
[admin@MikroTik] > ip/firewall/mangle/ print
Flags: X - disabled, I - invalid; D - dynamic
 0  D ;;; special dummy rule to show fasttrack counters
      chain=prerouting action=passthrough
 1  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 2  D ;;; special dummy rule to show fasttrack counters
      chain=postrouting action=passthrough
 3    ;;; Track Carplay connections
      chain=prerouting action=mark-connection new-connection-mark=carplay passthrough=yes dst-address=10.4.4.0/24 log=no log-prefix=""
 [admin@MikroTik] > ip/firewall/nat/ print
 0    chain=srcnat action=masquerade out-interface=wan_quantum log=no log-prefix=""
 1    ;;; RoadWarrior phone to VM
      chain=dstnat action=dst-nat to-addresses=10.0.4.16 to-ports=51820 protocol=udp in-interface-list=wans dst-port=51820 log=no log-prefix=""
 2    ;;; carplay-homeassistant-dst
      chain=dstnat action=dst-nat to-addresses=10.0.4.11 dst-address=10.4.4.11 connection-mark=carplay log=no log-prefix=""
 3    ;;; carplay-homeassistant-src
      chain=srcnat action=src-nat to-addresses=10.4.4.11 dst-address=10.0.4.11 connection-mark=carplay log=no log-prefix=""
 4    chain=dstnat action=dst-nat to-addresses=10.0.4.41 dst-address=10.4.4.41 connection-mark=carplay log=no log-prefix=""
 5    chain=srcnat action=src-nat to-addresses=10.4.4.41 dst-address=10.0.4.41 connection-mark=carplay log=no log-prefix=""
 6    chain=dstnat action=dst-nat to-addresses=10.0.4.43 dst-address=10.4.4.43 connection-mark=carplay log=no log-prefix=""
 7    chain=srcnat action=src-nat to-addresses=10.4.4.43 dst-address=10.0.4.43 connection-mark=carplay log=no log-prefix=""
https://help.mikrotik.com/docs/spaces/ROS/pages/3211299/NAT
netmap?
Not sure if this is an option for you, but if it’s just a handful of mobile devices and one CarPlay, you could configure them with static IP/mask/gateway/DNS, something like 10.0.0.0/24 or even shorter CIDR. Since you were going to touch all mobile devices anyway…
Oh man. This ‘netmap’ was it. Did exactly what I was trying to do. Alias my private an IP ranges to another IP range at the router level.
My final config that works:
 2    chain=srcnat action=netmap to-addresses=10.4.4.0/24 dst-address=10.0.4.0/24 connection-mark=carplay log=no log-prefix=""
 3    chain=dstnat action=netmap to-addresses=10.0.4.0/24 dst-address=10.4.4.0/24 connection-mark=carplay log=no log-prefix=""
Unrelated, but how did you discover this problem? I imagine getting the routing table form an iOS device was not trivial.
“netmap” is pretty useful trick in RouterOS. So that part make sense.
I’m curious too on the use case…
So you have a MikroTik on some car’s “LAN”, and want to enable your own VPN or something to the car?
I understood it that when an iPhone is connected to both a remote LAN (over WG) and to a vehicle (for Carplay), Carplay inserts a routing rule for 10.0.0.0/16 which makes resources on the remote LAN unreachable.
There are apps for that. I just checked my CarPlay connection with HE Network Tools app. In my case it’s 10.174.189.0/24, definitely nothing commonly used.
Speaking of /16, wouldn’t /24 routes take precedence being more specific? I suspect the OP has something like 0.0.0.0/0 over VPN.
Yes, unless policy routing is involved.
