Hi All
Im setting up a 450G with a PCC load balance script but need to include failover - the old TPLINK load balancer ended up with 2 dead DSL lines but still tried to route to the lines as the modem itself was up. Im therefore trying to ping a remote host external(past) the DSL router to make sure there is a working connection prior to using the port.
Eth 1-4 are configured a WAN ports using the following script which was provided by a member here from their website and seems to work well.
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
add address=192.168.3.2/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN3
add address=192.168.4.2/24 network=192.168.4.0 broadcast=192.168.4.255 interface=WAN4
/ip firewall mangle
add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_iconn
add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
add chain=input in-interface=WAN4 action=mark-connection new-connection-mark=WAN4_conn
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
add chain=output connection-mark=WAN4_conn action=mark-routing new-routing-mark=to_WAN4
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.4.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address-type=!LAN in-interface=LAN per-connection-classifier=both-addresses-and-ports:4/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
add chain=prerouting dst-address-type=!LAN in-interface=LAN per-connection-classifier=both-addresses-and-ports:4/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
add chain=prerouting dst-address-type=!LAN in-interface=LAN per-connection-classifier=both-addresses-and-ports:4/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
add chain=prerouting dst-address-type=!LAN in-interface=LAN per-connection-classifier=both-addresses-and-ports:4/3 action=mark-connection new-connection-mark=WAN4_conn passthrough=yes
add chain=prerouting connection-mark=WAN1_conn in-interface=LAN action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=LAN action=mark-routing new-routing-mark=to_WAN2
add chain=prerouting connection-mark=WAN3_conn in-interface=LAN action=mark-routing new-routing-mark=to_WAN3
add chain=prerouting connection-mark=WAN4_conn in-interface=LAN action=mark-routing new-routing-mark=to_WAN4
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 routing-mark=to_WAN4 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.4.1 distance=4 check-gateway=ping
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
add chain=srcnat out-interface=WAN3 action=masquerade
add chain=srcnat out-interface=WAN4 action=masquerade
Im now reading up here, http://wiki.mikrotik.com/wiki/Advanced_Routing_Failover_without_Scripting and it appears to be very simple to add remote failover checks. using the below:
add dst-address=Host1 gateway=GW1 scope=10
add dst-address=Host2 gateway=GW2 scope=10
add distance=1 gateway=Host1 routing-mark=ISP1 check-gateway=ping
add distance=2 gateway=Host2 routing-mark=ISP1 check-gateway=ping
add distance=1 gateway=Host2 routing-mark=ISP2 check-gateway=ping
add distance=2 gateway=Host1 routing-mark=ISP2 check-gateway=ping
My question is, Can I use that code as is (adding checks for the other gateways obviously) , or does it replace any of the code I had previously used regarding the routing marks?
If someone could take the time to post, maybe we could add a definative working PCC load balance with failover script to the WiKi as it appears to be a frequent question.
Many thanks
