Hi All,
Hopefully someone can help me with my predicament, I am trying to setup the port forwarding to get open NAT and getting some really weird results. using the latest release, also tried a lot of the fixes from the forum and net, so quite stuck now.
Before this I was trying to manually add NAT entries for port forwarding, but weird things when I run the game that requires the port, the game not continue further but displays a black screen, however when I disable the rule, the game will continue to load. Other weird output were sometimes it will show the bytes and packets, other times nothing.
So the rule below, I setup uPnP to see what ports are being used, however, to see if I could get an open NAT, however it is also not working.
Any help would be appreciated, thanks.
vincent
# oct/14/2021 20:39:12 by RouterOS 6.49
# software id = UX2G-130B
# model = RB750Gr3
# serial number = CC210EACEFA3
add admin-mac=zzzzzzzzzzzzzzz auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=xxxxxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/queue interface
set ether2 queue=ethernet-default
set ether3 queue=wireless-default
set ether4 queue=wireless-default
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.113 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.113 comment=defconf name=router.lan
established,related,untracked
invalid
add action=drop chain=input comment="defconf: accept ICMP" protocol=icmp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward connection-nat-state=dstnat
connection-state=invalid
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
/system clock
set time-zone-name=Asia/Kuala_Lumpur
/system identity
set name=MisterT
/tool mac-server
/tool mac-server mac-winbox
