hello ,
I have ask here about the band
http://forum.mikrotik.com/t/lte-interface-what-does-bands-3-7-20-mean/90363/1
and i know the modem (MC7700\MC7710) can work with this terms
but when I try to change I can’t see nothing
if I use this command
/interface lte set lte1 band=20
I don’t get any replay or error
and in the LTE interface - I don’t see any change
why is it?
how can I see if the change have change?
Thanks ,
uldis
December 3, 2015, 11:41am
2
that band command change is designed for different products
so it doesn’t work on the MC7700?
can you tell for which product they do work ?
Thanks ,
I suppose that its only for the new SXT LTE but it only works on band 3 an 7 with 15mhz channel providers.
In http://forum.mikrotik.com/t/lte-interface-what-does-bands-3-7-20-mean/90363/1 Kristaps explained that the command was only for the specific mini-pcie card he linked to.
The 7700 is a North American card and only does LTE bands 1, 4 &17 so even if the command worked with the chipset in the 7700 it couldn’t change to a band it doesn’t support.
The 7710 supports LTE band 20 among others.
