I’m trying to get UPnP to dynamically open incoming ports, with no luck, for the Transmission torrent client. I think it’s a firewall issue, because in Windows, routers and gateways (even those not mine) show up in my laptop’s Windows Explorer Network “Network Infrastructure” page.
Here’s my router’s configuration:
[admin@MikroTik] /ip> upnp print
enabled: yes
allow-disable-external-interface: no
show-dummy-rule: yes
[admin@MikroTik] /ip> upnp interfaces print
Flags: X - disabled, D - dynamic
# INTERFACE TYPE FORCED-IP
0 ether2-master internal
1 ether1 external
[admin@MikroTik] /ip firewall nat> print
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=ether1 log=no log-prefix=""
[admin@MikroTik] /ip> firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp log=no log-prefix=""
2 ;;; defconf: accept established,related
chain=input action=accept connection-state=established,related log=no log-prefix=""
3 ;;; IP address of public bandwidth tester
chain=input action=accept protocol=udp src-address=207.32.195.2 log=no
4 ;;; defconf: drop all from WAN
chain=input action=drop tcp-flags="" in-interface=ether1 log=no log-prefix="WANDrop "
5 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
6 ;;; defconf: accept established,related
chain=forward action=accept connection-state=established,related log=no log-prefix=""
7 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
8 XI ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 log=no log-prefix=""
Maybe the network type you have chosen for the network on your laptop is “Public” rather than “Private”? I think “Public” would not attempt to communicate with uPnP devices.
ether1 is definitely the WAN port and ether2-master definitely the LAN port:
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published, C - complete
# ADDRESS MAC-ADDRESS INTERFACE
0 DC 192.168.1.10 BC:5F:F4:57:8D:F8 ether2-master
1 DC 192.168.1.127 E4:9A:79:79:72:26 ether2-master
2 DC 192.168.1.129 00:18:F8:85:90:35 ether2-master
3 DC xx.yy.104.1 60:73:5C:72:23:D9 ether1
4 DC 192.168.1.125 90:FD:61:E3:8A:A1 ether2-master
5 DC 192.168.1.123 F8:CA:B8:52:4F:39 ether2-master
I mean on your Windows computer itself. When you first connect to a network, Windows asks you if it is a private network or a public network. If you choose “public”, or do not choose anything, it will assume public, and will not attempt to look for or interact with uPnP devices.
I’ve got two computers: a Windows laptop (where enabling UPnP and adding the interfaces allowed the Explorer Network Infrastructure page to see the RB750G) and a Linux desktop where I run a torrent client.
It’s the torrent client on Linux that can’t dynamically find an open port.
Since you have a WAN subnet, you could try explicitly setting a forced wan ip, like:
/ip upnp interfaces
set 1 forced-ip=xx.yy.109.84
> (or whatever the router's IP address is).
I'd have to change that every time that my ISP sends me a new address (often, since I must regularly reboot the modem).
> Also, I see that your last firewall rule ( no 8 ) is disabled, leaving your internal network unprotected.
From what? (This is a small, trusted LAN.)
> Could you try running the following file on your Windows laptop, it can be run using LINQPad which can be downloaded here:
> http://www.linqpad.net/
> <snip>
You’re right. I thought you had been assigned a /21 subnet but this is just the provider’s subnet not yours.
From malicious traffic Anyone in your provider’s subnet could send malicious traffic to your internal network. Even if your house is small, you shouldn’t leave the doors wide open..
The LINQPad example shows that the UPnP interface is running and accepting commands. So the question is; what isn’t working correctly?
Do you see the dnat entries appearing in the firewall NAT table? If so, check the counters and run packet sniffer to determine where the traffic is blocked.
If the dnat entries are not there, you’d better create a supout.rif and send it to MikroTik.
(If the dnat entries appear only when using the LINQPad example and not when running your torrent app, try restarting this application and/or the pc).
From malicious traffic Anyone in your provider’s subnet could send malicious traffic to your internal network. Even if your house is small, you shouldn’t leave the doors wide open..[/quote]
I thought that was what the rule “chain=input action=drop tcp-flags=“” in-interface=ether1 log=no” did. Whenever I enable logging, I see scads of blocked traffic.
That’s the case.
Did that many times when trying various permutations of settings.
That rule only blocks traffic targeted at the router itself, rather than traffic passing through the router, towards your internal computers.
chain = input is for traffic arriving at the router (as its final destination)
chain = forward is for traffic passing through the router (something else is the final destination)
To some extent, it is a guess. However, 192.168.1.0/24 is the most commonly used private subnet for home users, so the odds of this guess being accurate are fairly high. There are only 254 potential devices on this subnet, and so it doesn’t take long to try accessing all 254 IPs to determine if there is a response. If someone on the same ISP (and same public subnet) as you wanted to try to hack into your system, it would be relatively easy without that firewall rule protecting you. They could configure their router with a static route to 192.168.1.0/24 with your public IP as the next hop, and, without the ‘forward’ chain rule blocking, any packets they send to 192.168.1.x addresses would be delivered to your internal devices, and they would reply.
It is somewhat unlikely you will see anything in the log (especially in comparison to attempts on the input chain itself), but that doesn’t mean that you shouldn’t protect yourself from that attack vector. All it takes is one hacker on your ISP subnet who tries your IP to take advantage of this open door (which hackers elsewhere do not have access to) and they can have full access to your internal systems. Most home routers protect against this attack vector by default, so without a rule blocking incoming forwarded packets, your router is less secure than a typical D-Link or similar consumer router.
Sorry for playing the “have you tried turning it off and on again” - card.. But really before starting the process elimination you should’ve checked the obvious.
Please take the time to follow my steps. I have installed transmission on Ubuntu and tested UPnP. It seems to be working well:
dnet entries are created:
UPnP traffic is visible by sniffing traffic (could’ve filtered on port 2828):
Filter on http traffic (enter “http” as display filter without quotes)
Select one of the packets (preferably one of the subsequent POSTs), open context menu and go to Follow => TCP Stream (as displayed above)
Here you can see the request:
POST /upnp/control/okgmrxpsbp/wanipconn-1 HTTP/1.1
Host: 192.168.88.1:2828
User-Agent: Debian/jessie/sid, UPnP/1.0, MiniUPnPc/1.6
Content-Length: 607
Content-Type: text/xml
SOAPAction: "urn:schemas-upnp-org:service:WANIPConnection:1#AddPortMapping"
Connection: Close
Cache-Control: no-cache
Pragma: no-cache
<?xml version="1.0"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:AddPortMapping xmlns:u="urn:schemas-upnp-org:service:WANIPConnection:1"><NewRemoteHost></NewRemoteHost><NewExternalPort>51413</NewExternalPort><NewProtocol>TCP</NewProtocol><NewInternalPort>51413</NewInternalPort><NewInternalClient>192.168.88.237</NewInternalClient><NewEnabled>1</NewEnabled><NewPortMappingDescription>Transmission at 51413</NewPortMappingDescription><NewLeaseDuration>0</NewLeaseDuration></u:AddPortMapping></s:Body></s:Envelope>
@rohnjohn63: try downgrading to bugfix channel, 6.36.4. Do the linux host uPNP properly creates the dynamic dst-nat on IP > Firewall > Filter in this case?
