I’m genuenly stumped. I got a hAP ax3 router, booted it up with default config, set a static IP and the local IP i need, set up port forwarding for a few devices and whatever i try, it just wont connect me to the internet. What did i miss?
This is the config:
# jan/02/1970 00:30:19 by RouterOS 7.8
# software id = 11DN-3JX7
# model = C53UiG+5HPaxD2HPaxD
# serial number = <serial>
add admin-mac=78:9A:18:2C:99:1D auto-mac=no comment=defconf name=bridge
/interface wifiwave2
# must specify passphrase for PSK
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
configuration.mode=ap .ssid=MikroTik-2C9921 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
configuration.mode=ap .ssid=MikroTik-2C9922 disabled=no \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.105-192.168.1.248
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=81.XX.XX.XX/24 interface=ether1 network=81.XX.XX.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.1.198 comment=KAMERUSRV mac-address=1C:6F:65:53:72:BA
add address=192.168.1.208 comment=NEW mac-address=E0:3F:49:16:6A:B3
add address=192.168.1.139 comment=AND mac-address=E0:3F:49:16:6B:09
add address=192.168.1.140 comment=W10 mac-address=04:D9:F5:80:91:83
add address=192.168.1.132 comment=KAM_SERVER mac-address=C0:25:A5:8F:CB:C5
add address=192.168.1.175 comment=AXIS mac-address=B8:A4:4F:08:F3:41
add address=192.168.1.104 comment=PRINTER mac-address=00:17:C8:0D:BD:B7
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
192.168.1.1 netmask=24
set allow-remote-requests=yes servers=212.59.1.1,212.59.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat comment=kasa dst-address=81.XX.XX.XX \
dst-port=10097 in-interface-list=all protocol=tcp to-addresses=\
192.168.1.126 to-ports=10097
add action=dst-nat chain=dstnat comment=rdp dst-address=81.XX.XX.XX dst-port=\
3389 in-interface-list=all protocol=tcp to-addresses=192.168.1.198 \
to-ports=3389
add action=dst-nat chain=dstnat comment="cam web" dst-address=81.XX.XX.XX \
dst-port=81 in-interface-list=all protocol=tcp to-addresses=192.168.1.198 \
to-ports=81
add action=dst-nat chain=dstnat comment="cam 8000" dst-address=81.XX.XX.XX \
dst-port=8000 in-interface-list=all protocol=tcp to-addresses=\
192.168.1.198 to-ports=8000
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/tool mac-server
/tool mac-server mac-winbox
