Antenna coupling problem LHG 5axD
Hello everyone, could someone help me with the following:
I have two LHG 5axD antennas, one configured as an access point (AP) and the other as a station bridge. The settings are identical for both devices (SSID, security, channel, etc.), but when pairing the antennas, only one connects, not the other (antenna 1 shows full Wi-Fi signal bars, while antenna 2 shows nothing). When I'm connected to Winbox, I can ping both antennas, but on my PC, the pings only go through to the station bridge antenna. I'm in lab mode, and the antennas are in the same room and side-by-side.
It is not at all clear (to me) what you are reporting.
If the two devices are identical and have identical configuration[1], try swapping the mode (make the ap a station-bridge and the station-bridge an ap).
If the same device that currently "shows nothing" now shows full Wi-Fi bars (and conversely the one that now shows full WI-FI bars starts showing nothing) both devices are working and there might be a (simple or complex) issue in your configuration.
[1] do verify this first thing, making an export of each device and comparing them.
Here are instructions on how to export the configurration(s) and - if needed - upload them on the forum for review:
Forum rules - #5 by gigabyte091
Start with basic config
then modify what you need, like
antenna-gain=24 (or 25) not 16 on your model
