Antenna for BaseBox5
Does Mikrotik have a certain antenna for this product?
If not, which antenna is the common option to use with BaseBox5?
You can use any antenna on the same frequency of the mikrotik device
Thanks Plisken.
Any brand/model to suggest with 2 chains to use in 40km point to point link?
No for 40 Km links use a ubiquiti rocket dish.
http://www.balticnetworks.com/ubiquiti-airmax-rocketdish-5g-30.html
Thanks Plisken!
MikroTik has introduced their own antennas now:
http://www.mikrotik.com/download/share/MT_antenn_series_1.pdf
What is the price fo this dish antenna? Do you plan to have sector antennas?
It will be possible to buy Radom for this Parabolic antennas?
Not initially, but Radome will be available a little later as an accessory (it is mentioned in the brochure spec table in a few places)
Great Normis , there are we waiting for.
Finally, when they go on sale?
Excellent!
Sorry to revive this old topic, but with the recent introduction of new models, I have to ask.
Which of the two options should have a greater range?
  • BaseBox5 + mikrotik new antenna (MTAD-5G-30D3)
    or
  • The new QRT-5
Since MTAD-5G-30D3 has 30dBi antenna, and QRT-5 has 23dBi antenna, the Basebox + MTAD combo should give you better range.
