Inside my house I’ve a mesh network. It’s an old farm with very thick walls. Last year I put one of the satellites in the backgarden (in a plastic box), to my surprise this works pretty well.
But a part of the side of the house has no coverage. About 10 meters of the house a garage starts where I’ve about 200 Mbpps speed. And at the back of the garage I’ve about 150 Mbbps. I consider buying a Mikrotek NetMetal AC2 and set it up as a wireless repeater with the same SSID and subnet as my mesh network. Or I will buy a new satellite within my current mesh family.
At the start of the garage the antenna should be omni directional (HGO-antenna-OUT?) and at the end a 180 degrees antenna (but it also beams towards the house). What kind of antenna/hardware do you suggest?
Thanks for reading and hopefully responding,
Frank
