Antenna for recieve wifi repeat to ethernet
To access free public wifi to my home, I bought an antenna for receiving wifi-signals, and send it trought ethernet-cable to a wireless router in my house. Kind of wifi-repeater, only repeat to router trought cable.
The antenna (Groove 5hn) will not allowe me to connect via IP, so I downloaded Winbox to try configure it there. It was a little complicated, and I haven’t found any basic guides to set up the type of connection I need.
Do any of you have any beginners-tips for me, to help me set up this antenna?
Siggi
Are you sure the “hotspot” use 5ghz? Its not common to have 5ghz public wifi, but 2,4
No, i’m not sure. The guy in the show where I bought it reccomended this, I never really thought about the izzue 5 vs 2.4GhZ…
