Antenna for the RB751U
I am a little confused as to which external antenna I can use with the RB751U.
I read the right angle connecter does not fit. What are my options?
This is the only one I’ve seen.
http://www.balticnetworks.com/maxxwave-mini-2-4ghz-6dbi-omni-magnetic-wifi-antenna-mmcx-connector.html
Was RB751U even FCC certified for use with external antenna? I cannot find the info.
Probably, but you have to turn the power down but I am not sure. I have not heard.
