Which Antenna mode i must use, if i have only one antenna connected to main connector on R52H. Should it be antenna a mode? Now i have rx-a/tx-b. B is AUX connector on PCI-Mini? if it so, will it increase speed, if i’ll plug another (23dBi Grid) to A connector and reconnect Flat antenna to B connector. Hope you get my idea. Thanks
It realy depends on what card and chipset u use. Together with witch port on the card u are using to connect your antanna.
It also seems like some cards with only one connector ( sorry mikrotik) like R52X have a bug with a and b. Dont realy know how to explane the issue, but it seems like the card goes wild, becouse the chipset had antanna a and b, but the cards dont. This seems to mess up something.
