hello
I wont to get this item: chateau lte12. probably i need a antenna outdoor. please could you suggest me which antenna i have to buy. thanks
I’ll be grateful for any advice.
If you won’t get the item, then there is no point on an antenna.
It depends on what bands you have available to and if you need MIMO or not. Do you need Cat12 or is Cat6 enough?
For MIMO 2x2 X-Polarity I recommend this: L-COM HG72710XP-065
lololed
hello
very sorry for my english. I bought chateau 12 and it arrived yesterday. It doesn’t work. I got it from amazon.
all led turn on. eth1 can’t get the ip. I tried with static ip without solving. i don’t see wifi.
do i give it back? i guess yes
By default, is possible that eth1 is config as WAN port. Try to connect to the other ports to get IP over DHCP.
Regards.
Or wireless
I also have the Chataeu12 and requires a decent antenna. Do you have any recommendations that can be bought in (SE) Asia? Many thanks
For now I only tested L-COM HG72710XP-065 and MikroTik mANT-LTE-5O.
Regards.
