Antenna Polarity
Hi All
Can someone please help
For the SXT & Sextant can someone please confirm which chain is which Polarity
I never know which chain is vert and which is horiz
ch0 is H
Inox, I think it doesn’t matter, if ur doing PtP link.
The things that matter I believed is that the two devices should do the same thing.
I.e, if u did chain0 in H with the first device, then in the second device you should do exactly the same.
The problem is when u do Horizantal in chain0 in first device then you do Vertical in chain0 in second device.
Good luck..
I belive you realised that I wasn’t asking anything.
And is important for some of us to know wich one is H.
So be useful or read a book.
Hi InoX sorry for the delay
Thank you very much for taking the time to reply
and for pointing out it’s not just a case of matching config sometimes it’s not always mikrotik :slight_smile:
