Does Mikrotik plan to develop any long range 60 Ghz devices? In long range i mean 4km+. Curently i’m using two Nanobeams from UI, that perform quite well on a 3,4 km link, but for upgrade i was thinking of installing Mikrotik device but cannot find anything, that would work at such distance.
+1
Lack of such devices (longer range and PtMP up to 15 stations) recently forced me to start using competitor’s Wave AP Micro sectors + Wave Nano / Wave LR stations, but they are expensive (I was lucky to stockpile some just before the +30% price increase by the manufacturer, they clearly see they have a monopoly in this space), and I like the MT way of doing the backup (bonding on the station side, no special support on the AP side) better because it can use any existing 5GHz AP not necessarily the one integrated with the 60GHz AP, if only LHG/nRay had the backup radio as it is needed most over long distances (not needed so much for the short-range Cube).
