Any ideas, why this wireless cannot connect ?
I’ve got problem with one wireless, it is working fast enough, but when working little it stops and cannot connect to the ap again. miniPCI card is CM9. Software is Mikrotik 2.9.6, and the oposite side is the same …
10:22:26 wireless,info cm9-122-116: lost connection to 00:0B:6B:::, extensive data loss
10:22:27 wireless,info cm9-122-116: failed to connect to 00:0B:6B:
::, got deauth: class 2 frame received (6)
10:22:39 wireless,info cm9-122-116: failed to connect to 00:0B:6B:::, assoc failed: unspecified (1)
10:22:51 wireless,info cm9-122-116: connected to 00:0B:6B:
:: on 5***, SSID testw
10:23:03 wireless,info cm9-122-116: lost connection to 00:0B:6B:::, extensive data loss
10:23:03 wireless,info cm9-122-116: failed to connect to 00:0B:6B:
10:23:15 wireless,info cm9-122-116: failed to connect to 00:0B:6B:::, assoc failed: unspecified (1)
10:23:27 wireless,info cm9-122-116: connected to 00:0B:6B:
04:41:54 wireless,info cm9-116-124: 00:0B:6B:::** connected, wants WDS
04:42:07 wireless,info cm9-116-124: disconnected 00:0B:6B:::, reassociating
04:42:07 wireless,info cm9-116-124: data from unknown device 00:0B:6B:
::, sent deauth
04:42:07 wireless,info cm9-116-124: data from unknown device 00:0B:6B:::, sent deauth
::, sent deauth
04:42:31 system,info bridge group changed
04:42:31 wireless,info cm9-116-124: 00:0B:6B:::** connected, wants WDS
04:42:32 wireless,info cm9-116-124: disconnected 00:0B:6B:::, reassociating
04:42:32 wireless,info cm9-116-124: data from unknown device 00:0B:6B:
::, sent deauth
04:42:32 wireless,info cm9-116-124: data from unknown device 00:0B:6B:::, sent deauth
::, sent deauth
I had problems with the exact “deauth: class 2 frame recieved error”
Mikrotik - Still would like to know what this error means..
This would happen when we loaded the link. Switched channels and the errors and disconnects went away. Might be interference. Try a different channel if you haven’t already. I would also upgrade to the latest release 2.9.8
Dan
MT 2.9.6 is not stable if you are using 2.4 ghz .. I’ve had the same problem and my prism2 card got burned cuz of a storm..
now i’m using MT 2.8.26 and it work fine I dont’ get users disconnected and data loss ofcoure changed the prism2 card.
ps. talking about 2.4 ghz .. MT 2.9.6 works perfect in 5ghz
CM9 is 5 GHz.
I’ve change the frequence but I hadn’t chance to make some traffic weekends. I’m worried about too interrupts in work:
02:16:58 wireless,info cm9-122-116: lost connection to 00:0B:6B:::, extensive data loss
02:16:58 wireless,info cm9-122-116: failed to connect to 00:0B:6B:
02:17:10 wireless,info cm9-122-116: failed to connect to 00:0B:6B:::, assoc failed: unspecified (1)
02:17:22 wireless,info cm9-122-116: connected to 00:0B:6B:
:: on 5450, SSID testssid
02:19:46 system,info,account user admin logged out via winbox
02:20:12 wireless,info cm9-122-116: lost connection to 00:0B:6B:36:BA:2D, got deauth: class 2 frame received (6)
02:20:12 wireless,info cm9-122-116: connected to 00:0B:6B:::** on 5450, SSID testssid
But wireless connect after few seconds …
try to change your wireless card of AP .. cuz it’s maybe damaged ..
mine was damaged and worked as yours disconnects/connects
hope it will help u
I’ve changed the frequence and everything now works fine.
I’ve got a tower with 3 wireless cards set to ap-bridge and 3 remote mikrotiks. One week after this issue the other 2 cards got the same poblem, and I use the same way to repair them (changing the freq.).
Cards are new from box (they were working for 1 month).
But now i’ve got another problem I’m not sure is the reason the same (I’ve start another thread).
