RADVD Out-Of-Bounds Write Remote Code Execution Vulnerability
https://www.zerodayinitiative.com/advisories/ZDI-23-710/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2023-32154
12/09/22 – ZDI reported the vulnerability to the vendor during Pwn2Own Toronto.
eworm
May 18, 2023, 4:40pm
2
I guess Mikrotik has its own implementation and is not effected.
It’s an specific RouterOS vulnerability
r00t
May 18, 2023, 5:04pm
4
This one seems particularly bad vulnerability, especially if it’s in the router advertisement/neighbor discovery as described, as these are active by default and left enabled by most users:
This vulnerability allows network-adjacent attackers to execute arbitrary code on affected installations of Mikrotik RouterOS. > Authentication is not required to exploit this vulnerability.
The specific flaw exists within the > Router Advertisement Daemon > . The issue results from the lack of proper validation of user-supplied data, which can result in a write past the end of an allocated buffer. > An attacker can leverage this vulnerability to execute code in the context of root.
Larsa
May 18, 2023, 5:52pm
5
Is this a joke?
There is is no technical analysis, no info if it concerns RoS v6 or V7, and lastly CVE-2023-32154 does not even appear to be registered with NIST…
i think details are not revealed until a fix is released/confirmed, to prevent mass exploitation
https://en.wikipedia.org/wiki/Coordinated_vulnerability_disclosure
eworm
May 18, 2023, 6:04pm
7
Oh, my fault… I just read “radvd” and did not follow the links.
Well, we will see… Let’s hope we will have results in the coming days.
Larsa
May 18, 2023, 7:01pm
8
Well, then it’s either a leak at NIST (cve) or a fake.
normis
May 19, 2023, 11:15am
9
Blog entry following soon, together with RouterOS upgrade in all channels. Upgrade needed if using IPv6 advertisement settings.
So, for be clear, if is
/ipv6 settings
set accept-router-advertisements=no
no worry…?
normis
May 19, 2023, 11:20am
11
ONLY affected if:
ipv6/settings/ set accept-router-advertisemnets=yes
or
ipv6/settings/set forward=no accept-router-advertisemnets=yes-if-forwarding-disabled
Well, I have already configured all devices with this setting (set accept-router-advertisements=no) from the beginning
normis
May 19, 2023, 11:24am
13
Yes, it is certainly not normal to have it on. Somebody coud have it on by mistake, or in very specific scenarios.
If I do not remember bad the default on both v6 and v7 is accept-router-advertisements=yes-if-forwarding-disabled and forward=yes
Sorry, is also included 6.48.6 (long-term) and 6.49.7 (stable), over the 7.9 (stable) / 7.10beta5 (development)?
Thanks.
normis
May 19, 2023, 11:28am
15
RouterOS 7.10beta7, 7.9.1, 6.49.8 coming soon
pe1chl
May 19, 2023, 2:58pm
17
Blog? I did not know it still existed…
Is it correct this is already known for over 6 months ?
pe1chl
May 20, 2023, 6:01pm
20
No, blog = https://blog.mikrotik.com/
But nothing has been posted there for nearly two years...
