Does the beta expire at all or have any other kind of built-in limits? I really need the station-pseudobridge mode for one of my clients which means deploying the beta in the field. So far in my testing it appears to be pretty solid, I haven’t run into any major issues yet, but I’d rather know now about any built-in limits rather than get a call from my client.
If the installed copy is licensed, No “it will run for ever”
I belive…
I dont have “OFFICIAL” word from MikroTik, but I have never had a beta (that was licensed) expire. They just keep going and going and going…
I have been using MikroTiks for several years.
Just keep in mind BETA…
Good to know. It is licensed, so hopefully I won’t have any issues. I’ll keep testing it for a while though given that it’s beta to make sure nothing unexpected comes up.
license only gives you chance of upgrade and update to newer version. they should run forever if you do not change version numbers ![]()
