I need help! Trouble with Billing system
Is it possible to allow authentication for all users with any login/password MT v5.0rc7?
Thank you for help!
Depends on how you are authenticating guests. If it’s local authentication on the router itself, I doubt there is any way to do it.
If you are using a remote Radius server, you’ll need to look at their documentation, but there is usually a way to hard code an ACCEPT for everything in them.
Yes - local auth. on router
Then I don’t believe there is a way for you to do that. You could quickly set up a FreeRadius server and hard code it to ACCEPT and change the router to start using that. That will likely be the quickest, easiest, and cheapest solution for you.
