Any Mikrotik tech in Cambodia, Sihanoukville ?
I am a Software guy, but for a friend I am looking for a technician, capable to install MT equipment, incl. cable config.
To set up SXT LTE6 or similar.
https://mikrotik.com/consultants
Whom did you find on that page ?
Closest looks like Thailand or Vietnam
https://letmegooglethat.com/?q=cambodia+mikrotik+services
In Poland I recieved the proper answer as the fifth item.
Is it really nowadays so hard to ask any search engine or ChatGPT or any AI-like tool for an answer? Should be so simple problems solved from the opposite side of the Earth and bother so many people?
