wt is the Volt and ampire to rb433 and rb433ah to work good ?
notice without poe !!
thnx
The 18POW supply sold by Mikrotik is 24volts DC .8 amp (19 watts). This works fine with both RouterBoards and 1 or 2 low power radio cards (r52 or r52H) or 1 higher power card (like an xr2).
If you are running more radio cards then it is wise to use the higher power supply like the 24HPOW which is 24 volts at 1.6 amps (38 watts).
Tom
thnx mr. Tom
wt about the power ( volt and amp ) with poe !
in 433 , 433ah
r52 , xr2 and many xr2
thnx
I would use the 24HPOW 24 volt 38 watt supply and the RB/P54 passive POE injector when using more than one XR2 card with a RB433 or RB433AH.
I am not sure why you are saying “many” XR2. You can only fit two in the triple shot connector used on the RB4xx series RouterBoards.
Tom
thnx mr. Tom
i understood from you :
when i use poe , use 24HPOW 24 volt 38 watt supply in any case
right ?
plz any ans !
helppppppppppppppppp
Your question has already been answered. The case does not matter.
