any option for FTTH
exist proyect for hardware OLT by mikrotik? is a good idea low cost please
I am not satisfied with any Mikrotik OLT directions in the GPON market or the SIP market.
You will find zero to at the most almost nothing for support for a GOPN OLT.
I installed some Mikrotik GPON Modules and experienced a 100 percent failure rate. They all died in the early summer. I suggest if you try them , put them in front of an air conditioner and keep them at about 50 degrees F. The moment they get to early summer tempretures, is the moment they all died.
