Any timeline on IS-IS?
Our MPLS backbone consists of Juniper, cisco, and soon, Brocade routers. All run IS-IS on the interior. Currently all is LDP, but we are considering RSVP-TE to do better engineering. (It’s a fairly large and convoluted network.)
I could see using your rb750gs on the edge for our server farms. It would reduce the impact of single-points-of-failures (SPF). For example, instead of a large (but redundantly connected) Juniper box serving 48 servers. We would have 16 rb750gs boxes serving them. Each rb750gs would have a pair of redundant upstream MPLS ethernet links, and the other three ports serving 3 downstream servers (16x3=48). Now, if a PE device fails, it only kills three servers, not 48. Big win.
But, your box doesn’t do IS-IS, which pretty much kills the plan. Is this something you are working on?
OSPF is great for smaller networks, but it’s area/stub architecture does not work at large scale. We have learned that the hard way :slight_smile:.
A more trivial question: are 19" rack rails available for the rb750gs?
John
About IS-IS. Unfortunately there are no plans to add ISIS support in near future.
Too bad, I’d love to put some RB’s in much more of a CPE or PE/CE MPLS router position, IS-IS would make that easier in my network.
That is a shame :frowning:
