Hello
Have dude running on CHR VM. I’ve got a CA etc setup; I can create certs successfully for web interface - however whenever I goto apply the cert to the winbox port - it doesn’t accept it – is there any trick to getting it working?
Sean
seanwg,
If I understand correctly, at the moment we have two possibilities to connect to the Dude.
- Dude Windows client.
- ROS Webfig.
Dude Windows client uses Winbox port and should be secured by itself. You also may specify “secure” during connection.
ROS Webfig may be accessed via HTTP or HTTPS and here you may apply a certificate for HTTPS.
Thank you!
