This is a known issue with MikroTik and other vendors (Cambium and Ubiquiti in particular) with some devices. In my case specifically Cambium PTP radio’s connected to a MikroTik router
FCS errors are generated with very regular intervals,it’s not an actual frame error and is not caused by bad cabling, bad termination etc. Exactly 1 FCS error will be generated every 30 or 60 seconds, consistently, forever. If it was actually bad transmissions it would not be that consistent. It also doesn’t matter if there’s a little or a lot of traffic going over the port
I suspect its something internal in the radio’s that gets transmitted, maybe as its own ethernet up-state check, I don’t know and I don’t really care because nobody is accepting responsibility and nobody is trying to fix it
What I do need fixed is the logs filling up with FCS error messages and/or the counters. I want to use network monitoring software to look for actual, real cable faults in our network but I can’t because I keep getting false alarms every 30/60 seconds from many of the Airfiber and PTP devices in our network. So is there a way to filter these out on a MikroTik device on a particular port? I still want to see FCS errors on other ports, just not the ones I know are false alarms
