If your gateway address is the same, you need a seperate MT for each line, plus a 5th router, routing between the 4 MT routers, NOT the 4 Lines.
1 - MT1 -| 2 - MT2 - | 3 - MT3 - |-MT5 (Load Balance) 4 - MT4 -|
Works, been done many times…
– Chris
Could you just throw in some static arp entries for their gateway and give them fake addresses? Use the fake addresses in the gateway? Just a thought - might be totally off though .
I highly doubt that.
Data coming back in from the nas to x line won’t route properly either.
