Hi..
anybody can help?
Situation A —> all connection Ok
Situation B —> Internet connection keep (up & down) for all even LAN (A) & also ISP router
Thanks in advance
Hi..
anybody can help?
Thanks in advance
sounds like a misconfiguration. there are a lot of mistakes which can triggered such errors. please post a export of your configuration on the routeros device
/interface l2tp-server
add disabled=yes name=l2tp-in1 user=haibrosas
add disabled=yes name=l2tp-in2 user=haibrosas
/interface pptp-server
add disabled=yes name=pptp-in1 user=""
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
set [ find default=yes ] authentication-types="" eap-methods=passthrough
group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled management-protection-key="" mode=none
name=default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=
"" wpa2-pre-shared-key=""
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=
hotspot http-proxy=0.0.0.0:0 login-by=http-chap,trial name=default
nas-port-type=wireless-802.11 radius-accounting=yes
radius-default-domain="" radius-interim-update=1m radius-location-id=""
radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit=""
smtp-server=0.0.0.0 split-user-domain=no trial-uptime=30m/1d
trial-user-profile=default use-radius=yes
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=
aes-128 lifetime=30m name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=ether2 lease-time=3d name=dhcp1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default
use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
add kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32
pcq-dst-address6-mask=128 pcq-limit=50 pcq-rate=0 pcq-src-address-mask=32
pcq-src-address6-mask=128 pcq-total-limit=2000
add kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0
pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=
ospf-in metric-bgp=auto metric-connected=20 metric-default=1
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,
w
eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,p
a
ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test
winbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=yes keepalive-timeout=30 max-mru=1450 max-mtu=
1450 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:17:DF:7C:2D:42
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.88.1/24 comment=lan disabled=no interface=ether2 network=
192.168.88.0
add address=1.9.111.149/29 comment=wan disabled=no interface=ether1 network=
1.9.111.144
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.88.0/24 dhcp-option="" dns-server="" gateway=192.168.88.1
ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=4096 servers=202.188.0.133,202.188.1.5
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input disabled=no protocol=icmp
add action=accept chain=input connection-state=established disabled=no
add action=accept chain=input connection-state=related disabled=no
add action=drop chain=input disabled=yes in-interface=ether1
add action=masquerade chain=srcnat disabled=no out-interface=ether1
add action=dst-nat chain=dstnat comment="Linux SSH" disabled=no dst-address=
1.9.111.149 dst-port=22 protocol=tcp to-addresses=192.168.88.10 to-ports=
22
add action=dst-nat chain=dstnat comment="Linux HTTP" disabled=no dst-address=
1.9.111.149 dst-port=80 protocol=tcp to-addresses=192.168.88.10 to-ports=
80
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip ipsec peer
add address=0.0.0.0/0 auth-method=pre-shared-key dh-group=modp1024 disabled=
no dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=3des
exchange-mode=main generate-policy=no hash-algorithm=md5 lifebytes=0
lifetime=1d my-id-user-fqdn="" nat-traversal=no port=500 proposal-check=
obey secret="" send-initial-contact=yes
/ip neighbor discovery
set ether1 disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set l2tp-in1 disabled=yes
set l2tp-in2 disabled=yes
set pptp-in1 disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=
no src-address=0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=1.9.111.145 scope=30
target-scope=10
add disabled=no distance=1 dst-address=192.168.100.0/24 gateway=10.0.100.2
scope=30 target-scope=10
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set "" address="" disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=1m use-radius=yes
/ppp secret
add caller-id="" disabled=no limit-bytes-in=0 limit-bytes-out=0
local-address=10.1.10.1 name=banjaria password=test profile=
default-encryption remote-address=10.1.10.2 routes="" service=l2tp
local-address=10.0.100.1 name=haibrosas password=password profile=
default-encryption remote-address=10.0.100.2 routes="" service=l2tp
local-address=10.1.10.1 name=raintree password=test profile=
default-encryption remote-address=10.1.10.3 routes="" service=l2tp
local-address=10.1.10.1 name=user3 password=test profile=
default-encryption remote-address=10.1.10.4 routes="" service=l2tp
local-address=10.10.10.1 name=fathipptp password=test profile=
default-encryption remote-address=10.10.10.2 routes="" service=pptp
local-address=10.3.0.254 name=rnas1 password=rnas1 profile=default
remote-address=10.3.0.1 routes="" service=any
local-address=10.3.0.254 name=rnas2 password=test profile=default
remote-address=10.3.0.2 routes="" service=any
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
/radius
add accounting-backup=no accounting-port=1813 address=192.168.88.10
authentication-port=1812 called-id="" disabled=no domain="" realm=""
secret=testing123 service=ppp,hotspot,wireless timeout=300ms
/radius incoming
set accept=yes port=1700
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators=""
trap-target="" trap-version=1
/system clock
set time-zone-name=Asia/Kuala_Lumpur
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=ACM
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=217.26.64.149 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
400MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=""
/system upgrade upgrade-package-source
add address=192.168.88.1 user=admin
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool netwatch
add disabled=no down-script="" host=10.10.10.2 interval=1m timeout=1s
up-script=""
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=
"" filter-mac-address="" filter-mac-protocol="" filter-port=""
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s
use-radius=no
