Anyone got terminal within Winbox immediately disconnected when connect Winbox with MAC Address?
When I’m opened terminal within Winbox it’s disconnected immediately as screenshot, it’s happened when connect Winbox with MAC address.
How to avoid this problem?
Thank you.
Related to this ?
http://forum.mikrotik.com/t/why-does-in-winbox-terminal-via-romon-requires-a-whitelisted-ip/167206/1
Hmm, in my case I get an error.
Does /user/active/pring detail report the connection?
same after i update into 7.9.2 this time..
EDIT: it works now in a couple of minutes.
hello there
i have an RB951G-2HnD-IN
i get the same error after i upgraded to 7.9.1 when I first experienced this.
i upgraded to 7.10, no dice.
i upgraded to 7.10.2, still the same error.
does anyone have an idea on how to fix this?
i also experience this with my CCR2004-1G-12S+2XS, CRS328-24P-4S+RM, and cAP ac.
I downgraded to version 7.7
terminal now works.
I upgraded to version 7.8
terminal still works.
I guess this is a bug in version 7.9 and up?
I had the same problem with v7.11. The only way to fix it was to reset configuration and re-apply if from script backup. Hope this will help you.
