Anyone has a copy of userman package for RC1?
This package is very small so if you could send it to my email address below or a link to download then it’s much appreciated. Thank you.
kaytee@teacher.com
For which platform.
I386 / Routerboard ??
for intel/AMD PC thank you
Sent.
PS Also you can usualy obtain older files from the MikroTik web site.
Hover over the link for the newest version, and jot down the file name.
Enter the name of the file you want with the version data changed to reflect the version you need.
They usualy do not remove the files, they add the most current and update the links, so if you request an older file by file name, you will get it…
Craig
They removed this file :slight_smile: Well I think they should have these available in case people need to use the older version that work for them.
Thank you for your email and the file. You are the champ!
