does anyone have working IKEv2 vpn server running on ROS 6.40+, working with windows and mac? If yes, can you please post your config and ROS version?
EAP is not possible for server, only for client (6.45.6, throws error “Only EAP client supported”).
Certificates don’t work or have issues on ROS 6.40+, with errors “unable to get local issuer certificate” and “local issuer certificate depth 0”, Downgrade to 6.39.3 solves this.
Mikrotik has changed IKEv2 heavily, the old examples don’t work (Road Warrion IKEv2 one) refer to non-existing fields or values, even just value names
are just changed to make a huge mess (rsa signature in 6.44.5 is digital signature in 6.45.6 etc)…
I’m fine with both EAP or certificates, as long as it works on both pc and mac.
edit - there are many unanswered posts regarding this, like
http://forum.mikrotik.com/t/ipsec-unable-to-get-local-issuer-certificate/127920/1
http://forum.mikrotik.com/t/vpn-with-rsa-sig-and-ikev2-issues-with-windows-7-client/133882/1
but some also state it works for them
http://forum.mikrotik.com/t/road-warrior-remote-access-using-ipsec-ikev2-with-cert-authorization-for-multiple-users/128124/1
thank you
