Anyone have the same problem with the hotspot system?
anyone using mikrotik to do hotspot?
Do your hotspot clients complaining sometimes they login their username, the system will say “Radius server is not responding”?
Then need keep login a few times just can successful login.
Between the login for userman, sometimes i cannot login, it will says “what XXXXXX inactivity”
Anyone have the same problem?
i m using hotspot & radius, but not facing such issue yet
Increase the timeout value on your mikrotik-embedded radius client ; i personnally found that the defaut value is way too low, i have put it to 3000ms and i now have no more problems.
i had increase, but still happened..
I am using 2 CCR for my network, one is radius, one is hotspot..
