anyone having this problem at v6.28?
After i upgrade to v6.28, my router will stop function after sometimes, i cannot using winbox login, cannot get ip address from DHCP server, the router like totally freeze, i need to physically turn off the power and on the power again?
It is happened on my CCR1016-12G.
Anyone having same problem?
Is this hardware or software problem?
How long until you see those issues?
I’m on v6.28 on an RB951G-2HnD unit here with an uptime of 22 hours. No issues yet.
Did you try SSH login?
and what’s the error appeared in winbox?
cause I had same issue but not like this…
I’m at 4 days, 22 hours on all 17 of my CCR’s and 4 days 17 hours on my RB’s with no issues. Have you checked your scripts? Try disabling any scheduled items, maybe something is crashing.
1d 6hrs with no issues on v6.28
i’m good 1d 20h
