anyone using LtAP mini on Verizon is the US?
Their IMEI site says it won’t, T mobile says maybe on one page and won’t respond on another.
AT+T wants my birthday before I can sign up so I’m hoping to avoid them.
Anyone got a good data SIM plan they use with this?
Hi, I use AT&T sim card on LtAP mini. It will be quite difficult if you want to use the voice card (the normal one we put in our phone), instead, I applied for a unlimited data card ( eg. for tablet, no voice function). And it works quite well.
Thanks, I really hate doing business with AT+T but might be stuck with them.
Did you get a firstnet card or regular consumer one?
Verizon doesn’t recognize Mikrotik hardware IMEIs but their towers don’t filter for IMEIs its strictly at the business office end. My workaround was purchasing a broken Verizon MiFi and using that IMEI to obtain a SIM. I placed the SIM in the Mikrotik and it worked.
I just have a regular consumer one. ( So I have two sim card, the regular one for my iphone and the other one, which is the data card for tablet installed on my LtAP mini).
Michael, I think I met you in the Pittsboro post office 2 years ago, I use to do the teams and tracks 2 way radios.
I have a Verizon SIM from a mifi but it’s too small, I put it in the slot and it disappeared, had to use a very small screwdriver to get it out.
I have a broken mifi but it’s back there and I’m in AZ for a few weeks to escape the snow, will try it when I get home.
Need any tech help this season? Nice to see Hinch got a ride, know his crew chief for many years.
You probably met my boss - he lives in Pittsboro. I didn’t start here until mid-2019.
Yes. For those what I had to do was buy a SIM card adapter kit to adapt the micro-SIM to the larger SIM to fit the Mikrotik LTE modem slot. I found them on Amazon. https://www.amazon.com/gp/product/B00R25GJJW
For MiFis that I bought that didn’t have a SIM and I bought one from Verizon, they sent an “all in one” SIM - just punch out the correct sized SIM card.
My local Verizon store gave me an adapter and I got the SIM in the Mikrotik, now my LTE interface shows a MAC, network modes and IMEI but the status tab has
SIM not inserted. The SIM is in as far as it will go, the locking lever is about the 10 o’clock position.
It took a few attempts to get the SIM lined up just right for the routerboard to read it. You may need to pop it out and reinsert it.
