anyone using MT on portwell hardware…
see http://www.portwell.com.tw
Yes, I do (successfully
). Running on several models. But beware that the CF slot on Portwell boards always is the secondary IDE port, so of no use for MikroTik. You have to use an IDE flash module or an ide-to-CF adaptor…
is the lcd doing anything…???
don’t mean the buttons, know i can forget about that.
but is the lcd display working under 2.9?
Nope - it has a serial interface, but have not taken any time trying to get it running…
what kind of solution is this?
What do you mean?
which purpouse serves the portwell ? is a board where you put the mk os?
Portwell is manufacturing a whole range of embedded devices (desktop to big rackmount) which can also run MikroTik RouterOS. Perhaps take some minutes to scan through their webpage http://www.portwell.com.tw.
cmit, on what platforms did you already succesfully run MT?
do you know a european distributeur or a online shop???
Hey piwi,
drop me an e-mail at info cmit.de …
