There was a discussion about required HW for wave2 drivers and disk size larger than 16MB was IIRC one of them. Supported devices (Audience, hAP ac3) have 128MB storage …
Probably it is because of the 16M storage size. The official documents said " it is required at least 10M free space" . cAP ac has total of 16M storage , most likely , there is no 10M left for wave2 package.
@gotsprings,
Thank you for the reminder ! I noticed that it is not compatible with CAPsMAN before I tried to install the wave2. My problem is that I even cannot install the wave2 package on the device.
The actual firmware / kernel modul for IPQ40xx based devices (like cAP ac) would small enough to fit in a smaller wifiwave2 package which could be used on e.g. cAP ac with its 16MB of ROM. Unfortunately MikroTik hasn´t released anything like this.
Custom tools for creating your own *.npk packages (like https://github.com/kost/mikrotik-npk) don´t work unfortunately.
Thats the point brg, you will absolutely be able to use wifi5 proper implementation of wave2, with Capac2, which has not been released yet
Dont hold your breath! If they do it will be around the time all other vendors have cleaned up their initial wifi6 releases.
