RB433 + ROS 4.5 + R52N + AirMAX Sector 16/120(2pol) 2 connectors plugged into card.
I have clients A only but in the future will also in N.
name=“ap_xx” mtu=1500 mac-address=00:0C:42:XX:XX:XX arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name=“000C42xxxxxx” mode=ap-bridge
ssid=“xxx” area=“” frequency-mode=manual-txpower country=poland antenna-gain=0 frequency=5300 band=5ghz-a/n scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none wds-mode=dynamic
wds-default-bridge=lan_xxx wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=abp disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-extension-channel=disabled ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 hw-retries=4 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0
A - client works fine, but my questions are : Can i connect clients on 2 polarization separately. For exemple : 10 clients on vertical 10 on horizontal (A band) and additional clients on N with 2 pol. anntenas ?
It’s config right ?
It’s chain config right?
What with wds in this situation ?
What with hw-retries ?
Thx for help!
