AP as router
can i use mAP or hAP lite as a router with full firewall for my office?
can i connect it to some WiFi network, configure NAT and give Wifi to my computers?
thank you.
Yes, every mikrotik device running RouterOS can act as a router.
The only concern is the throughput that you will get from it.
You can use the QuickSet tool to setup the basic ANT routing.
do you mean you want to make your device acts as an extender?
not actually extender.
some my clients work in one big office and use shared WiFi. I would like to secure my clients. They use VPN connection on each laptop, but a would like to configure only one connection on Mikrotik.
i can’t extend current WiFi because i’m not an administrator of that.
I still do not understand what you want.
Can you explain the problem and your desired situation?
Better yet, draw a picture.
It is possible. Question how much it is smart…
question is - how much it will be secure for company B
It will be as much secure as much securely it will be set. If you let the company B to set it on their own, it will be surely secure enough for them.
thank you.
P.s.: i’m Company B
