when the mikro running ap bridge mode , station pseudobridge ,
connect another ap ,
Can the mikro’s SSID be normal broadcastiing , and serve wifi clients ?
the ssid seems not working … wifi client can not camp on
I have tried one virtual ap , still not working
Or should I create 2 virtual ap , one for wifi client
the other for wifi station broadcasting SSID ?
thanks !
I would like to set up the following;
set up a WLAN AP and then create a VLAN and put the AP insite
of the VLAN, thats it.
jengjr
May 29, 2014, 10:58pm
3
jengjr:
thanks !
I doubt this is can NOT be done .
'cause the master wlan1 interface is psudobridge mode , the virtula ap created upon that master interface
Can’t see vlan setting will do any help .
However the FONera can divide 2 ar0 ar1 interface , one for wifi bridge , the other still normal wifi station ssid broadcasting !
Set up more than one vap and name them something like as “guest” and “privat”
would this helps you out.
jengjr
May 30, 2014, 10:57pm
5
Sorry NO !
the key is we can’t use vap as wifi client to connect another ap,
All the vap is under the master wlan0 interface , which works Psudobridge mode
so how the vap can work as different Station mode,
I don’t think so .
