Hi m8s!
I’m trying to set up AP bridge + WDS using this manual http://wiki.mikrotik.com/wiki/Wireless_repeater
With AP Bridge configuration without activating WDS i have signal, but after i activate the WDS and adding the “slave interface” wds, Praia_AP as master interface i don’t have 2.4Ghz signal. What could be the problem?
my configuration:
/interface wireless> print
0 name=“Praia_AP” mtu=1500 mac-address=xx:xx:xx:xx:xx:43 arp=enabled
interface-type=Atheros AR5212 mode=ap-bridge ssid=“MT_LINK_PQ”
frequency=2462 band=2.4ghz-onlyg scan-list=default antenna-mode=ant-b
wds-mode=static wds-default-bridge=none wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=Praia_AP
compression=no
/interface wireless wds> print
Flags: X - disabled, R - running, D - dynamic
0 name=“MASTER_AP” mtu=1500 mac-address=00:00:00:00:00:00 arp=enabled
master-interface=Praia_AP wds-address=xx:xx:xx:xx:xx:63
I have a RB433 3.14 with Compex WLM-54G23 200mW 54 Mb/s
A question a “little bit” off-topic, In the building near by there are GSM and UMTS antennas, can the radiation block the signal? I know that they operate at diferent frequency.
Best Regards,
deckard
