AP clients do not receive IP from the router to which the AP is bridged
Hey!
711 / 5.000
wAPG-5HaxD2HaxD is bridged with C53UiG+5HP axD . I want only C53 to give IPs, wAPG is connected on LAN to C53. I deleted DHCP server and client on wAPG-5HaxD2HaxD. I put wifi1, wifi2, ether1 and ether2 in bridge, I deleted firewall filter and nat on wAPG-5HaxD2HaxD. The AP's LAN and wifi clients send DHCP requests which I sniffed and saw that they reach C53UiG+5HP axD but it does not give them IP. The C53UiG+5HP axD is also bridged to Ubiquiti AP which works perfectly and its clients receive IP from C53. What is the problem that under no circumstances do the wAPG-5HaxD2HaxD clients receive no matter what settings I make?
Hi @astanciu . Sounds like a config issue. Can you post them? Don't forget to use the preformated style.
