AP Configuration
well i have the RB411AR with 6.13 firmware.
i want to use it like AP.
my default gateway is 192.168.1.1
ip range 192.168.1.2-192.168.1.254
is any tutorial step by step how to?
thanks
connect to your router and use the Quickset and configure your board.
i do it all ready but what about in internet? aytomatic, pppoe, static? etc?
if your ISP provides you dynamic IP using DHCP then you can specify Automatic - it will get the IP from the DHCP server.
still nothing, maybe i do something wrong with configuration
i do the quick setup, then i connect the AP to my router, but still don’t have internet on AP
please help
please contact support@mikrotik.com with support output file attached and also the ISP configuration that you have.
