AP do no register in WLC
I have an AccessPoint that is connected directly to mikrotik and I need to register on WLC 5508, but its not working.
Some advice.
Just do some configurations delete them and configure again but still not working.
What exactly do you want to register ?
I’m pretty sure Cisco WLC only works with Cisco APs … and vice versa.
Mikrotik’s solution, somehow resembling wireless controller, is CAPsMAN.
@mkx thats what i thought too…
I have a Cisco AP AIR-CAP2602I-E-K9 and its connect directly in Mikrotik but the AP is not registering in WLC.
Already configure the vlans and still not registering.
/interface vlan
add name=vlan301 vlan-id=301 interface=ether4
add name=vlan100 vlan-id=100 interface=ether4
add name=vlan200 vlan-id=200 interface=ether4
add name=vlan201 vlan-id=201 interface=ether4
set ether4 default-vlan-id=301 vlan-header=add-if-missing vlan-mode=fallback
add address=172.27.224.140/24 interface=VLAN301
Try to describe your topology a bit more into details. I can only speculate (based on what you wrote so far), that Cisco AP is connected to port ether4 of your MT and that it needs a few VLANs flowing to make it work … and that somewhere in your LAN (supposedly) there’s a Cisco WLC which should receive connection from Cisco AP. You did not write where’s that WLC connected, you did not write how your LAN is configured (which should include detailed configuration of MT device in question), you did not even write device type of your Mikrotik …
So we are in deep dark here and really can’t help you with that.
BTW, what you configured most likely won’t help you solve the problem … because what you did is create a bunch of interfaces that allow MT to interact with VLAN devices off ether4, but you most probably want to pipe those VLANs towards Cisco WLC instead.
WLC is headquartered at the company where I work and mikrotik is located in another place, the main objective is introduce the AP in the place where is the mikrotik, connecting him directly to MT and try to regist in the WLC where it is in the Headquarter.
At this moment im making tests with other mikrotik i have with me with the main objective is order to be able to register AP on WLC connecting him directly on this Mikrotik I have with me.
Consider at this moment i have a Mikrotik with me and the AP to making tests.
Mikrotik Model:
model = 951Ui-2HnD
